2000 Chevy Venture No cold air
DJRAY92
Air Conditioning problem
2000 Chevy Venture 6 cyl Front Wheel Drive Automatic
I had a radiator flush done on my van, the air condidtioning was working perfect until they did the flush and now I have no air conditioning what so ever.. Is it possible that they knocked something loose or something come unhooked?
Any help you can give on this would be greatly appreciated..
Thank you
Aug 5, 2010 at 5:41 AM
FREEMBA
  • 1,152 POSTS
Check the 2-wire connector at the a/c compressor underhood. The compressor is located below the radiator hose which goes to the water pump. They could have accidentally unplugged it during the other repair.
If that is OK. Have the a/c system pressures read at an a/c shop--system may be low or out of freon. (otherwise, only explaination for this to happen just after a service is human error)
Aug 22, 2010 at 8:33 AM
