2000 Chevy Venture My Chevrolet Venture has this problem
JOSE221
Electrical problem
2000 Chevy Venture 6 cyl Automatic 165000 miles
I did the inpection to my 2000 minivan because it didn't want to start. The inpection said these.
Purge or vent solenoids defective
check connector and wiring
Fuel saturated vapor canister
Failed EVAP vent solenoid
Ignition system fault-spark plug(s), ignition
Vacuum leak
Injector fault
high or low fuel pressure
Poor electrical connection
Faulty purge solenoid
How can I fix this problems
Sep 27, 2009 at 1:50 PM
  • 110,248 POSTS
Okay, that sounds like a lot, but I think most are related.
Basically everything you mentioned deals with the EVAP system. However, that won't stop the car from starting. I would recommend having the EVAP system fogged to determine if the problem is coming from a leak that is undetectable by eye.
As far as the spark issue, that will cause it not to start. Have you checked to see if there is spark? Is there power to the coil? Have you checked the crank sensor?
Dec 14, 2009 at 12:12 AM
