2000 Chevy Venture Hub Assembly Replacement
135,000 MILES • 6 CYL • FWD • AUTOMATIC
BARTLETTVENTURE1
How do you determine that the hub assembly needs to be replaced.
Jul 28, 2009 at 11:56 AM
HEYOU100
  • 6 POSTS
Steering either left or right, the noise or hum should increase or decrease. If the noise gets worse when you turn the vehicle to the right, then the left bearing needs replaing, (steering to the right puts more weight on the left front wheel). If the noise gets worse when you turn the vehicle to the left, then the right bearing needs replaing, (steering to the left puts more weight on the right front wheel).
Apr 22, 2010 at 12:28 PM
