2000 Chevy Venture front end
CORBYZMOM
Suspension problem
2000 Chevy Venture 6 cyl Automatic 199000 miles
How do I know if the tie rod ends need to be replaced in my van? it pops in the front end, mostly when you turn.
May 11, 2009 at 1:20 PM
RHALL77
  • 3,361 POSTS
you need to jack the front end up off the ground and shake the front wheel and see if anything feels loose. you could also have a ball joint causing the problem
May 12, 2009 at 1:49 AM
