2000 Chevy Venture computer plug in under dash
2000 CHEVROLET VENTURE
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONEYWASHERMAN
Have Chevy Venture with check engine light on, when i took to mechanic and then auto parts store to have them check code, thir scanner would not "boot" up (no power from van). I have bought a computer to install and the dealer will then reprogram computer BUT is there a problem with the hookup under the dash, since it wont power up hand held scanner?
Mar 8, 2008 at 12:22 PM
ED ARMES
  • 129 POSTS
The test equipment connects directly to the computer. If the computer has failed completely, you will get no communication from the computer. However you could just have a wiring harness problem to the computer.
Mar 16, 2008 at 4:13 PM
