2000 Chevy Venture Codes that won't go away...
135,000 MILES • 6 CYL • FWD • AUTOMATIC
HOPPYTOE69
I had two codes (P0141 and P0341) register so I had a mechanic repair the P0341 (camshaft position sensor) and I replaced the "post" oxygen sensor (P0141). The light cleared for a day or two then has come back on. I had them run the diagnostic and both are still on there even after I ran it over 500 miles. I'm thinking I have an issue with the computer and not the actual sensors. Your thoughts?
Larry
Aug 16, 2008 at 7:11 AM
JETSA
  • 117 POSTS
I would think if it were the computer itself, it wouldnt had cleared for 2 days. Sounding more like a wiring issue to me, such as maybe a group of wires rubbing through and touching ground or each other at times. It is possible it is the computer, just doesnt sound like a computer issue to me. I checked and the 2 sensors do not share any circuits. The only thing they have in common that I can see is the computer.
Aug 16, 2008 at 8:08 AM
