2000 Chevy Venture a/c radiator fan won't come on
175,000 MILES • 6 CYL • FWD • AUTOMATIC
COLLEBR
The air conditioner radiator fan will not come on resulting in engine overheating when air conditioner is running at slow vehicle speeds or idling. I replaced a relay with no effect.
Aug 11, 2009 at 1:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle has 3 cooling fan relays. have you inspected all 3 relays?
Dec 18, 2018 at 10:32 AM
COLLEBR
I checked the other two relays. Removing them stopped the main engine cooling fan. I assumed they had nothing to do with the a/c cooling fan. Am I wrong? The relay I replaced was black, with five, not four prongs. The others are grey with four prongs. Do you think replacing the other two relays would help?
BLUELIGHTNIN6
  • 16,542 POSTS
test the fan motor to ensure it works. supply 12v power to it and see if it comes on
