1999 Chevy Venture THERMOSTAT
LINDYLOO
Engine Cooling problem
1999 Chevy Venture 6 cyl Front Wheel Drive 1000.0 miles
CAN YOU PLEASE TELL ME WHERE THE THERMOSTAT IS ON MY VAN.
Feb 22, 2009 at 6:59 AM
BMRFIXIT
  • 19,053 POSTS
Follow upper radiator hose to engine
its under the throttle body you may need to remove exhaust cross pipe
Feb 22, 2009 at 7:06 AM
F4I_GUY
  • 3,302 POSTS
That's great advice by BMRFIXIT, and he is correct.
However, if you just remove the exhaust crossover heatshield, you can remove the thermostat housing. It may be a bit awkward to remove the thermostat bolts, but it is definately manageable and better than trying to remove rusted bolts and nuts on the exhaust.
Goodluck.
Feb 22, 2009 at 7:17 AM
