1999 Chevy Venture Power Window only goes one direction
106,000 MILES • 6 CYL • FWD • AUTOMATIC
MONTESS84
I put my drivers side window down today and it wouldn't go back up. I replaced the switch, nothing.
I took the panel off and pushed the window back up and replaced the motor. Upon powering it up, the window went down but again, didn't come back up. I took the motor off and hit the switch again. Sure enough, the motor only turns in one direction.
Any help is appreciated. Thanks!
Feb 11, 2010 at 11:26 AM
SERVICE WRITER
  • 9,123 POSTS
Reman parts can be defective off the shelf. IF you get 3 in a row, then I would go in a different direction. But I have seen too many that were diagnosed correct only to have a bad part question their integrity.
Feb 11, 2010 at 11:29 AM
