1999 Chevy Venture Loss of brake pedal pressure while engin
1999 CHEVROLET VENTURE
102,000 MILES • 6 CYL • FWD • AUTOMATIC
PAULMABEE
the brakes loose pressure while running. When the engine is off the brakes load and function. Can the problem be Vacuum related?
Apr 11, 2009 at 9:05 AM
If its not leaking anywhere and its running and you feel the pedal sinking I suggest you replace the master cylinder it has an internal leak
Apr 11, 2009 at 11:28 AM
