1998 Chevy Venture rear brakes
1998 CHEVROLET VENTURE
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
BGK51
abs light is on. brake light is on. there is no hydraulic pressure going to the rear drum brakes. the front disc brakes are fine. tried bleeding the system but could not get any thing to the rear. please help
Aug 27, 2008 at 10:42 AM
SERVICE WRITER
  • 9,123 POSTS
You need to find out what codes are present. There will be some abs codes and the will likely lead to the solution of both symptoms. The ABS unit may need to be bled by use of a hand held diagnostic computer.
Aug 27, 2008 at 11:36 AM
