1998 Chevy Venture My rear air doesn't work
156,000 MILES • 6 CYL • FWD • AUTOMATIC
JONMAC81
Hello im near here and was wondering if I could get some help on my van. My rear air doesn't work. I try using front and the back controls and nothing happens. Could you tell me what might be wrong? Also my thermometer doesn't work on my over head console either. Could it be a fuse on both that I have missed or what? Thanks
Aug 5, 2010 at 9:35 AM
FREEMBA
  • 1,152 POSTS
when you say that the rear a/c doesn't work, do you mean that the blower doesn't come on when you turn the a/c on or do you mean that the a/c doesn't get cold?
if it's the blower motor not coming on, check the rear blower motor fuse (in underhood fuse box--check the inside fuse box also for any fuse which may effect the a/c).
Check for power at the blower motor resistor (rear left fender--behind plastic side panel).
Aug 22, 2010 at 8:29 AM
