1998 Chevy Venture fuel pump relay??????
133,000 MILES • 6 CYL • FWD • AUTOMATIC
JABURLEIGH
i have a 1998 chevy venture it has 133000 miles and the fuel pump quit working if you short a hot wire to the relay it begins working the relay isnt bad what could be the problem?
Sep 13, 2008 at 1:35 PM
RHALL77
  • 3,361 POSTS
you have either a bad ground or a bad voltage circuit at the junction box. there should be a ground, a signal wire to the pump and 2 voltage wires.
Sep 18, 2008 at 3:46 PM
