1998 Chevy Venture Fuel leak
1998 CHEVROLET VENTURE
126,000 MILES • 6 CYL • FWD • AUTOMATIC
DOUGSKI
1998 Chevy Venture has a fuel leak about 3 feet from the fuel tank or the middle of the mini van engine starts up and i can move it but it streams out very rapidly when i do is there an easy fix or do I need to tow it in to a shop?
Mar 21, 2010 at 12:40 AM
LEGITIMATE007
  • 5,121 POSTS
well it may very well be an easy fix, you just have to determine if its coming from the fuel line or around the fuel filter . if its in the line, go to autozone and see what kind of products they have to repair it. I've seen people take a piece of a garden hose and cut out the area that is leaking and put each end into the hose and clamp it on both sides with a worm clamp, just as a quick fix, but the parts stores have the correct tubing to do this
Mar 21, 2010 at 2:37 AM
