1998 Chevy Venture Cooling fans not working
130,000 MILES • 6 CYL • FWD • AUTOMATIC
LVVOLVO
I just recently purchased a used 1998 Chevy Venture Van. The previous owner has hot-wired a switch to the cooling fans so they run constantly once the vehicle is running. Can you tell me what could be the problem thats keeping the fans from blowing.
I would like to remove the wiring and get the van back to the regular way of cooling without using an external switch. Thanks
Jun 16, 2010 at 10:32 AM
  • 75,988 POSTS
Inspect and test the fan relay, coolant temperature sensor, also if it has an engine coolant temperature gauge switch check that too-if both okay its coming from the computer
Dec 18, 2018 at 10:32 AM
