1998 Chevy Venture Boggs
1998 CHEVROLET VENTURE
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
EVANS_09
Hi, im asking about my 98 chevy venture when in park or neutral at a light stop sign or whatever it bogs realy bad and the temp needle doesnt stay up Do U have a couple ideasof what this could be
Jun 30, 2010 at 6:02 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 30, 2010 at 12:48 PM
