1998 Chevy Venture ABS
1998 CHEVROLET VENTURE
155,272 MILES • 6 CYL • FWD • AUTOMATIC
BMARTIN24018
I had a scan done on the van and it came back saying my ABS rear motor is bad. where exactly is it? i can not seem to find a picture or diagram of where it is. Can anyone help?
Jun 19, 2010 at 6:52 PM
SATURNTECH9
  • 30,869 POSTS
If you could tell me what the code number you have in your abs computer is i can get you the information you need.
Jun 19, 2010 at 7:28 PM
BMARTIN24018
i cant remember, i had it written down, it came back saying rear abs motor is bad
Jun 20, 2010 at 9:06 AM
SATURNTECH9
  • 30,869 POSTS
I emailed you the replacement procedure for replacing the rear motor.I also emailed you a rear motor code trouble tree there are several of them just so you can see that they don't just tell you to replace the motor.That there could be other thing's causing the code's.If i were you i would get your code's read again and if you give me the trouble code i can get you the trouble tree for that code.I would hate to see you spend all that money on the part and all the work of replacing it and it not be the problem.That's up too you i emailed all the information to your personal email.
Jun 20, 2010 at 12:17 PM
BMARTIN24018
ok, so i still cant find that code, but, i did find out that it may not be m ABS motor after all. went to the dealership, to get prices, and a tech came out and did a few things and said my master cylinder is leaking, ( the pedal geos down slowly while your foot is on it) and he said that that alone could give a false reading. is there a way to bleed the brakes after i replace that with out having to pay big bucks to hook the computer up to it?
Jun 25, 2010 at 11:32 AM
SATURNTECH9
  • 30,869 POSTS
I only see it bleeding using the scan tool and running the abs motor's.
Jun 26, 2010 at 11:18 AM
