1997 Chevy Venture ac only blows cold out passenger side
QUICKDRAW2148
Air Conditioning problem
1997 Chevy Venture 6 cyl Two Wheel Drive Automatic 140xxx miles
my '97 venture vans a/c blows cold out the passenger side and hot out the drivers side. i have no idea why this is happening. what could cause this? i had a new compressor put on it last year. any ideas. this just started about a week ago.
Aug 13, 2010 at 9:03 AM
FREEMBA
  • 1,152 POSTS
seems to be a bad blend door actuator or a rpoblems where the door connects to the rod which the actuator operates.
Get a diagram of the system from the GM dealer, make sure it show the actuators (at least 2) on the a/c system. The one which moves when the temp is moved from cold to hot or vice versa is where you want to focus.
Aug 21, 2010 at 7:43 AM
