1996 Chevy Venture wipers
1996 CHEVROLET VENTURE
REZZ
1996 Chevy Venture 6 cyl
why are my windshield wipers staying in up position when they are turned off?
Aug 14, 2010 at 3:54 AM
FREEMBA
  • CAR REPAIR CONTRIBUTOR
  • 1,152 POSTS
OK. Locate the Black 48-pin connector C201. It is mounted on the left side of the steering column near it's base and has a bolt whic holds it together.
Turn the ignition switch to RUN position and the wiper switch to OFF position.
Disconnect connector C201 and observe wipers. If wipers park (goes to proper place when turned off), replace wiper/washer switch.
If not let me know and I'll send more info.
Aug 21, 2010 at 2:28 PM
REZZ
disconnected pin connector and turned key on and wipers off. no change.
Aug 22, 2010 at 5:34 PM
GMTECH
  • 537 POSTS
The problem lies with the wiper crank arm, not lining up with the park tab. This part connects the wiper motor with the transmission.
Oct 25, 2010 at 7:33 PM
