1995 Chevy Venture tie rod
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
VH1681
my van's front end shaks a little when im driving and the insides of my tires are wareing. i asked a machanic and he said it was th tie rod, that it wouldnt do any real damage it would just be annoying. does this soung right to you and how much does this usally run to get fixed?
May 11, 2008 at 3:15 PM
  • 31,937 POSTS
Hi there,
get the tie rod ends replaced this will take about 1/2 Hr , you should get an alignment as well, if a tie rod ends brakes, you will loose all steering. You will have to contact your local repaired for a quote.
Mark (mhpautos)
May 11, 2008 at 5:08 PM
