Stuck in park
CHARLIE504
I have a 1993 Chevy G20 van. auto trans. When I press the brake and try to move it out of park it wont move. Is there a switch that has gone bad. When i can get it out of park everything works great. till i put it in park again. Thanks for any help you can give me. Charlie
Nov 20, 2007 at 10:40 AM
MIKE H R
  • 3,094 POSTS
when you put your foot on the brake do you hear a click, it should be the neutral safety switch disengaging so you would be able to shift it. if the neutral safety switch goes bad then it will not shift out of park.
Nov 20, 2007 at 11:14 AM
