rear differential gasket
STAVEM
1992 Full size Chevy van, 223,780 miles, 350 engine.
Had oil changed and they said that my "rear differential gasket is leaking".
What's the rear differential and if it's more than just the gasket, what am I looking at to fix it?
Apr 15, 2007 at 7:28 PM
DBOAZ
The differential is that big pumpkin located in the center of your rear axle. It is an ingenious invention that transfers the power from the drive shaft out to the rear wheels. When you are going around a corner the rear wheels rotate at different speeds. If the differential were not there to allow this to occur then one of the tires would "hop"; llike driving a go-cart. Check out http://auto.howstuffworks.com/differential.htm for a better description.
The gasket leaking is not all that uncommon and it should be replaced. With that many miles you should replace the gear oil in the differential anyway, and changing the gasket would accomplish this as well. As for cost, it is hard to say but I doubt that it would cost more than $100
Apr 17, 2007 at 3:30 PM
