fuel supply problem
JONES02
76 chev g20 van 350 ci auto trans quadrajet carb. vehicle sits most of the time. van runs good but if not started for 2 or 3 days in a row has to be primed with gas to the carb. fuel pump? best guess?
Nov 23, 2007 at 4:55 PM
  • 31,937 POSTS
Hi there.
After car has been sitting for a few days, before trying to start, remove air cleaner and look down in side carby use a torch so you can see clearly, DO NOT TRY TO START. hold open choke butterfly and operate throttle a few times. See if there is a good stream of fuel from the throttle pump. If little or no fuel, i would suspect a possible faulty power valve allowing fuel to drain away over a few days. Start there.
Mark (mhpautos)
Nov 23, 2007 at 6:07 PM
