Cruise Control problem
STAYLOR1
I have a 2004 Chevy Venture Van, Automatic, 6 cylinder, 51,157 miles, 2 wheel drive. The cruise control doesn't work 95% of the time. When it does work, it goes on and off. The fuse is fine and doesn't blow. What else can I check?
Jun 24, 2007 at 8:37 AM
JBWMS
My cruise control module we out at ~80Kmiles. It did not work at all, so I don't know if you are having the same problem.
I replaced it myself. You can find the part on the gmpartsdirect.com website. It cost ~$150 I think. Piece of cake to install. The only trick is to remove the accelerator cable clip from the engine side.
Send me a message if you want.
Jonathan
Oct 23, 2007 at 3:25 AM
