break light
VEGDWK
I applyed my breaks at a stop and now my break light wont go off, tryed to manual realise the emergency break, but this did not fix the problem, the breaks are about a year old, help
May 25, 2007 at 8:08 AM
BOBBYL1966
  • 5 POSTS
I am not mechanic but if you mean your brake light stay on in the dash check your brake fluid maybe is low. If you mean the brake lights stay on like when you apply the brakes check the brake switch is in under the dash and check your brake bulbs too if is ok. Brake switch is not cost too much for you replace is in auto zone cost around $18. Is easy to replace too your self. If you see your fluid level is ok no drive the van bring to the mechanic for check
May 3, 2008 at 3:12 AM
