2003 Chevy Van blinking headlights
160,000 MILES • V8 • 2WD • AUTOMATIC
JCOX
when i turn on headlights both headlight and console
lights flash off and on
Aug 22, 2009 at 12:42 AM
MERLIN2021
  • 17,250 POSTS
I would check the headlamp switch and connector, sounds like a loose wire/connection. Check for bent or pushed out pins, if all checks OK, scan for codes with a scanner comparable to a GM TechII scan tool.
Generic scanners wont read BCM...
Aug 22, 2009 at 6:41 AM
