2002 Chevy Van stalls while driving
2002 CHEVROLET VAN
109,000 MILES • V8 • 2WD • AUTOMATIC
MPART
van starts fine then after driving about 15-20 miles hesitates then stalls. wont start for about 1/2hr to hr.
Jun 30, 2010 at 12:11 PM
Next time it refuses to start-don't wait for anything-Do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jun 30, 2010 at 1:45 PM
