FUEL PUMP RELAY?
RPOHTO
fuel pump is good i think the relay is shot where would that be and is there a test?
Jul 10, 2010 at 12:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the fuel pump relay is in the underhood fuse block (on left side of firewall). to learn how to test a relay, check out this link the location of the relay is below.
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Jul 10, 2010 at 2:11 AM
3MEANDOGS
no fuel from tank to engine, drove home after purchase at auction. stopped twice to refuel, engine started and ran fine each time. got home, parked overnight, went to start the next day...will not run. tries to turn over, but is starving for fuel. , fuel is not being transferred to engine spraying starting fluid into engine will start the van, but it will not stay running
Nov 12, 2020 at 2:59 AM (Merged)
HMAC300
  • 48,601 POSTS
if the engine started then it 's probably the pump not the relay check fuel pressure shodlbe 9-13 psi auto parts rent gauge you may need an adapter as well. see pic for relay underhood item 3. if the gray wire has power then check at tank that is wire leading to pump.
2CP-ARCHIVES
  • 4,540 POSTS
where is the fuel pump relay on my van?
  • 110,248 POSTS
It should be under the hood here is a guide to help test it with the fuel pump relay in the diagrams below.
LMALL
  • 0 POST
Thank you this site is great! I can't believe it is free.
