2000 Chevy Van leak to rear heater
160,000 MILES • V8 • 2WD • AUTOMATIC
TRYGG LIENG
Leak from brass fitting to rear heater system.Afraid of freeze tonight. Will engine be damaged after leak stops in 15 degree weather? Anti-freeze leaks right out.
Dec 11, 2009 at 12:36 PM
MIKE H R
  • 3,094 POSTS
No and Yes, If all the water leaks out then there would not be enough to freeze and cause damage. If just some of the water leaks out then it could crack the block. If it is that cold out I would have anti freeze in it. If you have to bypass the heater so there is no leak and add antifreeze
Dec 26, 2009 at 2:44 AM
