1997 Chevy Van No heat from heater
94,825 MILES • V8 • 2WD • AUTOMATIC
MCCORVEY
Took my car into the shop because the heater didn't blow cold air when fan was operational. Mechanic indicated radiator (cooling system) was leaking the water from the engine. I took to someone to fix the leak who informed me that I also have a leak in the head gasket. I need to know the estimated repair cost for the repair of the cooling system, to include the water pump and head gasket if replaced or properly repaired.
May 9, 2008 at 4:04 AM
  • 75,988 POSTS
If your headgasket is leaking it will be overheating go somewhere else to fix the problem, get out of Dodge now-
May 11, 2008 at 8:57 PM
