1995 Chevy Van wire diagram
1995 CHEVROLET VAN
130,567 MILES • V8 • 2WD • AUTOMATIC
TY68
just sent a question . 1 more also put driving lights on front bumber. do i need a relay on that?.gone to put a on/off switch inside for that light
Mar 7, 2009 at 5:43 AM
JAMES W.
  • 2,394 POSTS
As long as you tie into your regular headlight circuit or switch, and you use a heavy enough switch, you won't need a relay. BUT, From where ever you pull your power source, make sure you put in a fuse or you may wind up with a melt down. Hope this helps.
Mar 7, 2009 at 10:48 AM
