1995 Chevy Van Will not shift out of park
113,000 MILES • V8 • 2WD • AUTOMATIC
AMREF
What would make the vechicle difficult to shift from park?
Oct 7, 2009 at 9:22 AM
TWO66MHZ
  • 17 POSTS
[quote:3d03847afc="amref"]Transmission problem
1995 Chevy Van V8 Two Wheel Drive Automatic 113000 miles
What would make the vechicle difficult to shift from park?[/quote:3d03847afc]
Bent linkage, steering column issues. It could even be a problem with the valve body on your transmission. You would have to start by disconnecting items from your shifter and try them one at a time until you find something that is stiff. Pick one end and start from there. Sometimes you can see something physically preventing it from moving, i.e. wires from a recent alarm install. Hard to tell with out actually looking at it.
Good luck with your problem and I hope you can figure it out.
Nov 3, 2009 at 8:05 AM
