1995 Chevy Van Possible transmission or speed sensor proble
230,000 MILES • V8 • 2WD • AUTOMATIC
JRSANTINO
I can drive in any gear and shift smoothly intil i get to about 40 mph and then my van acts like its in neutral.
Before i replace transmission i want to rule out other possibilities. Any suggestions?
Sep 13, 2010 at 5:05 AM
  • 75,988 POSTS
Inspect and test the TPS and VSS sensors if okay-Get the transmission pressure tested-its slipping
Sep 13, 2010 at 8:38 PM
JRSANTINO
[quote:9c41b40db3="rasmataz"]Inspect and test the TPS and VSS sensors if okay-Get the transmission pressure tested-its slipping[/quote:9c41b40db3]
Sep 14, 2010 at 4:24 AM
