1995 Chevy Van Jerking/jumping when put into gear.
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
EVERETT KETTNER
After I start the van, the first time I put it in gear it jerks or jumps forward. Also, when it shifts into the next gear it does the same, only not quite so bad. After I have driven for 15-20 minutes it seems to smooth out and at times goes completely away. I had the transmission fluid and filter changed - no help. I had a rebuilt transmission put in at about 90,000.
Nov 28, 2009 at 9:53 AM
  • 75,988 POSTS
Inspect and test the IACV,TPS and MAP sensor
Nov 28, 2009 at 9:41 PM
