1995 Chevy Van FUSE
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
CONWAYS
My van ran out of gas, so i put gas in the carb.
it will run until the gas is gone, i need to find the fuse, or fuse's for the fuel pomp.
thank you.
Sep 15, 2010 at 1:04 AM
WRENCHTECH
  • 20,758 POSTS
Your truck doesn't have a carb, it's fuel injected. The fuel pump is located inside the fuel tank.
In tank fuel pumps are cooled and lubricated by the fuel in the tank. When you run a car out of gas, it pumps a lot of air through the pump which overheats it and causes some severe wear and many times, failure when they cool off.
You will need to use a fuel pressure gauge to verify this
Sep 15, 2010 at 1:40 AM
