1995 Chevy Van dies at traffic lights
166,000 MILES • 6 CYL • 2WD • AUTOMATIC
KINGSNAKE3
Replace thermostat, the old one was hollowed out. the van ran well enough. Now when it gets to operating temp. she has power surges while idling, and at traffic lights she dies. Have replaced a few switches, oil pressure switch, Tps, and temp. sensor.
What is the problem, and solution or am I just suppose to hollow out another thermostat?
Jan 29, 2009 at 5:25 AM
RHALL77
  • 3,361 POSTS
when was your last tune up. do you have a check engine light on? how does it run when its cold?
Jan 29, 2009 at 7:41 AM
KINGSNAKE3
When she is cold she runs very good, and idles perfect. Has a vortec motor, have replaced plugs, cap, & rotor.
Jan 29, 2009 at 8:10 AM
RHALL77
  • 3,361 POSTS
have it scanned for trouble codes. it sounds like when it goes into closed loop thats when it acts up
Jan 29, 2009 at 8:41 AM
KINGSNAKE3
Just wanted to say thank you for your time, and help. Just got throught changing O2 sensor, and it didn't help. Looking for trust worthy shop that will work with someone that is laid off, and not much cash. Have a good day, and thanx again.
Jan 29, 2009 at 9:17 AM
