1993 Chevy Van No reverse or first gear
BNDEWIT
Transmission problem
1993 Chevy Van V8 Two Wheel Drive Automatic 235xxx miles
My transmission has a slight leak out of the rear seal but I am sure to keep a check on my transmission fluid level. When I backed out a few times the last few cold days it didn't want to go, so I have been warming the van up. today I reversed otu of the drive-way just fine, but after that it would not reverse. I check out the other gears. It wouldn't go when I put it in 1st, and when its in drive or overdrive it takesa bit to go, but it still feels like it engages a little, just without the kick it didn have, when i put it in reverse or any setting.
is there a possibility it could be an easier fix? I'm thinking about doing a transmission flush, but I don't know if its forgone at this point.
any suggestions would be amazing.
thanks again.
Ben
Feb 15, 2008 at 6:46 PM
DAVEMAYWOOD
  • 8 POSTS
I hate to be the one to tell ya but you need a tranny rebuild there is no cheap way out don't waste your money on a flush
Feb 15, 2008 at 9:50 PM
BLACKOP555
  • 10,386 POSTS
Its not as bad as that!, it may just be the seal since the 1st *low* and reverse gear share the same seal and the same piston, it could be bleading off pressure causing the other gears to have a spot of trouble.
Feb 18, 2008 at 1:45 PM
