1993 Chevy Van brakes not releasing
40,000 MILES • V8 • 2WD • AUTOMATIC
BLLYNCH
The front brakes take 2-3 minutes to release after taking your foot off the pedal. I have replaced the calipers, the master cylinder, and i have completely bled brake system with new fluid. The van has set up a lot over the years, and it has 4 wheel ABS. I don't know if it's ABS system, the proportioning valve, or whether it needs a complete system flush or what. There are no warning lights on. I am currently on unemployment and don't want to put it in the shop unless I have to.
Jan 23, 2009 at 11:40 AM
  • 75,988 POSTS
Check the ABS system-when you bleed the system did you bleed the master then the ABS then the wheels?
https://images.2carpros.com/forum/automotive_pictures/12900_b1_6.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_b2_6.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_b3_6.jpg
Jan 24, 2009 at 12:00 PM
