My motor home engine stop after 60 or more miles
runing, it star again after 2 or 3 times and finish a trip
will be the ignition coil, the gas pump, or some sensor?
engine 5.7 liters van 30 G series
thank you
jose
SPONSORED LINKS
Monday, June 22nd, 2009 AT 12:31 PM
JDL
MECHANIC
Hello, start with the basics. After it stalls, if the vehicle refuses to start right away, have a helper crank it, while you check for spark at the plugs. Use a gage, check fuel pressure. Are there any codes?
