1992 Chevy Van water in oil
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
MITCHELL32
I have a 92 G-10 van with a 4.3l engine. I have water in the oilpan but none in the cylinders. It will spit water out of the vent tube from the drivers valve cover to the aircleaner. Is this a head gasket or cracked block? If water was in the cylinders i would say head gasket. Please help
Feb 16, 2009 at 4:15 AM
  • 75,988 POSTS
Get it block and pressure tested to find out where its leaking-could be the gasket, cracked head or block -intake gasket
Feb 16, 2009 at 4:24 AM
