1992 Chevy Van Throttle Position Sensor
240,000 MILES • 6 CYL • 2WD • AUTOMATIC
MITCH WHITE
Where is the Throttle Position Sensor located. I don't seem to be getting enough gas to the engine. It actually dies out if I step on the throttle too much. Some one told me this may be the problem.
Aug 28, 2008 at 8:56 AM
  • 31,937 POSTS
HI there,
i would do a scan first just to check for any set fault codes, you don't always get a fault light with a code set. i would be checking all the basics first before messing with the TPI sensor..
mark (mhpautos)
Aug 28, 2008 at 11:02 PM
