1992 Chevy Van Shifter
1992 CHEVROLET VAN
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAPPLE
My 92 chevy G-10 Shifter is "loose" that is there is no positive detents as you move the lever thru its range. The trans operates as it should down and up shifts you just have to move the lever around to find the correct gear. The shift cable and lever itself are secure, it appears the problem is in the ball and sliding detents that are around the column. Hope this is a common problem. Thanks Peter
Jan 22, 2008 at 1:00 PM
2CARPRO JACK
  • 11,533 POSTS
First you need to drive the pin up out of the column to free the shifter to see if it is worn/broken or if the problem is in the column. There should be a spring in there, watch for it.
Jan 23, 2008 at 7:56 AM
