1992 Chevy Van fuel pump
KB7KLT
Engine Mechanical problem
1992 Chevy Van V8 Two Wheel Drive Automatic
where is the fuel pump and filter on a 1992 g20 chevy van
Aug 10, 2008 at 12:45 PM
FROGSLIPS
  • 6 POSTS
have someone remove gas line at carb or injector inlet. turn key over check color of gas for water and trash , check pressure,
if not enough gas replace filter inside frame
rail passenger side, not enough gas
pitched lines on top of gas tank, from gas pump inside tank, pump has a filter on it also inside tank,, tank had to be dropped and cleaned.
frogslips
Aug 22, 2008 at 4:09 PM
