1992 Chevy Van Air Conditionion kicks on and off
11,500 MILES • V8 • 2WD • AUTOMATIC
ROBWSTN
With engine running and warmed up, I'll turn on the A/C. I can hear the A/C compressor kick in for about 2 seconds, then it "kicks out" for about 5 seconds... then, it kicks in again for about 2 seconds, and then it kicks out for about 5 seconds. This goes on and on till I shut off the A/C.
With all of this, slightly cooler air does come from the vent, but certainly not what has been in the past.
Never had any issues with the A/C in the past.
Is there some type of relay or "switch" that needs to be replaced?
Many thanks!
Rob
Mar 12, 2008 at 7:54 AM
MERLIN2021
  • 17,250 POSTS
Sounds more like it needs to be recharged!
Mar 12, 2008 at 7:56 AM
RHALL77
  • 3,361 POSTS
you are low on freon. Need to refill and find the leak. Your cycling switch is turning the compressor on and off.
Mar 12, 2008 at 7:57 AM
MASTER TECH DAN
  • 83 POSTS
system has leak and needs to have a dye put in it and recharged and rechecked for the leak
Mar 12, 2008 at 7:58 AM
MERLIN2021
  • 17,250 POSTS
You might have a leak, but there is normal leakage in all auto a/c of an acceptable level, don't know off the top of my head what the limit for yours is, but after 16 years of service, I am not surprised that it needs a bit of refilling!
Mar 12, 2008 at 8:25 AM
ROBWSTN
Many thanks!! Perhaps I've been lucky with this van; this is the first issue I've encountered.
Thank you for your quick and very timely responses! Now that you have provided me with some knowledge, this will certainly make my visit to the "garage" more tolerable!
Regards,
Rob
Mar 12, 2008 at 8:44 AM
