1992 Chevy Van
191,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEN CHRISTNER
I blew a rear brake line. I fixed it no problem there. But I have no brake fluid comming out of the line.I trided to reset the proportioning valve but it does not seam to move is there a hint something else to look at.
Aug 18, 2008 at 5:14 AM
DOCFIXIT
  • 18,828 POSTS
Try bleeding thje front this will center valve that closed off rears when line went. Also is there a rubber cup on one end of valve. If so push it in.
Aug 18, 2008 at 5:19 AM
