1990 Chevy Van Serpintine belt
13,900 MILES • V8 • 2WD • MANUAL
AIRJUAN2010
  • 6 POSTS
My sepintine belt keeps falling off ill tighten last a couple of days then i go start it and it falls of all pullys seem fine should i bypass the a/c pulley will that work im out of reasons why it keeps falling off
Aug 21, 2010 at 1:03 AM
WRENCHTECH
  • 20,760 POSTS
It's falling off because there is a problem with one of the pulleys. It may be an alignment issue or there may be wear in one of the components that allows to pulley to tilt at an angle which will cause the belt to migrate right off the edge.
You need to install the belt and then examine it very closely. Look for one pulley that's not in alignment or one where the belt seems to be traveling to one side. It usually requires the tension of the belt to expose thiss issue.
Aug 21, 2010 at 1:54 AM
AIRJUAN2010
  • 6 POSTS
Thanks for answering my Question i will look very closley wish me luck
Sep 5, 2010 at 2:26 PM
WRENCHTECH
  • 20,760 POSTS
Good luck. Let us know what you find.
Sep 5, 2010 at 2:28 PM
