1990 Chevy Van I INSTALLED A NEW FUEL PUMP AND IT DONT WORK
1990 CHEVROLET VAN
98,000 MILES • V8 • 2WD • AUTOMATIC
MONSHEEKA
I INSTALLED A NEW FUEL PUMP, WITHOUT DISCONNECTING THE BATTERY CABLE. NOW, THE FUEL PUMP DOES NOT WORK. WHAT IS THE CAUSE OF THE PROBLEM, AND HOW DO I SOLVE IT?
May 16, 2010 at 10:07 AM
When you turn key on do you hear the fuel pump come on? If not check the fuel pump fuse and fuel pump relay. If so check the fuel pressure if its within specs even though its new might be coming on but not producing pressure.
May 16, 2010 at 10:22 AM
CONSAKA
  • 31 POSTS
[quote:883884a30e="MONSHEEKA"]Electrical problem
1990 Chevy Van V8 Two Wheel Drive Automatic 98,000 miles
I INSTALLED A NEW FUEL PUMP, WITHOUT DISCONNECTING THE BATTERY CABLE. NOW, THE FUEL PUMP DOES NOT WORK. WHAT IS THE CAUSE OF THE PROBLEM, AND HOW DO I SOLVE IT?[/quote:883884a30e]
Solve it by first troubleshooting the problem. unplug the pump and verify you have voltage at the wires. It is possible you got a new pump that was bad. Happens all the time.
May 25, 2010 at 3:07 AM
Dunno -but they do fail though its new
May 25, 2010 at 9:22 AM
CONSAKA
  • 31 POSTS
more then one? if more then one fails it is time to start looking as to why? what part is failing? is it the motor winding? the wires where it plugs in? Further testing should reveal the problem area.
May 25, 2010 at 10:50 AM
Check and test the fuel pump relay it powers the fuel pump for 2 secs then deactivates, when engine fires up the fuel pump/oil pressure sending unit powers the pump constantly-could be a voltage drop problem also check the ground side of the fuel pump
May 25, 2010 at 10:58 AM
