1989 Chevy Van uses lost of gas
120,000 MILES • V8 • 2WD • AUTOMATIC
SHORELINE11
I have a G20 Van and recently it just started to use lost of feul.. I mean really heavy.. 5 gallons for every 24 miles. No check engine light nothing. I did a tune up 8500 miles ago along with the o2 sensor and the TPS since the engine light was on back then.
HELP!
Feb 22, 2008 at 1:09 AM
MERLIN2021
  • 17,250 POSTS
Check the pressure regulator and the return line to the tank, pull the vacuum hose off the regulator, any fuel in there? if so replace it, pinch the return line does pressure increase? Get a test guage, autozone rents them out, when your done they refund all your rental fees...
Feb 22, 2008 at 1:22 AM
