1989 Chevy Van coil leaking I think.
120 MILES • V8 • 2WD • AUTOMATIC
PBFROMID
The windows fogged up,so I stopped and the coolent was dripping heavly on the ground passenger sideb so I checked inside and a very small amount was under the heater on the passengers side. I drove it home a few miles It did not over heat, I checked the coolent the next day it was very low filled it up started it an it was leaking out under heater. My reapir manual says you have to lower the steering colum to R&R the heater coil could you give me some direction. should I remove the cover under the hood next to the blower motor to first make sure it is the coil and not a hose connection.
Nov 22, 2009 at 4:59 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I will check out the procedure on Mitchell 1 and post what i can find, as i am in Aust i won't get access to Mitchell for a few Hrs, as i am at work and i have access from my home PC only.
Mark (mhpautos)
Nov 22, 2009 at 10:25 AM
  • 31,937 POSTS
Hi there, there are a few different series i really need to know which van and which series, the more information you can supply the easier it will be to find the exact information for you.
mark
Nov 22, 2009 at 7:02 PM
PBFROMID
the van is a G20
Nov 24, 2009 at 6:05 AM
PBFROMID
sorry its to late .
Nov 24, 2009 at 11:35 AM
THIS IS MIKE
  • 686 POSTS
Your refund is complete. We are sorry we could not help you.
Nov 24, 2009 at 12:45 PM
