1987 Chevy Van Replacing the Starter
83,000 MILES • V8 • 2WD • AUTOMATIC
BREEZE38
What is the procedure to replace the starter on this vehicle? Thanks!
Mar 1, 2008 at 3:43 AM
MERLIN2021
  • 17,250 POSTS
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! use caution removing the last bolt. Install is the reverse of the proceedure!
Mar 1, 2008 at 3:45 AM
